Printing problems with Generic / Text Only in 2016. NAV puts spaces and CR LF in my printout.
Have tried MIBUSO first so this is a copy:
I have a report, in RTC 2016, that prints data to a lable printer. Simply printing variables Row1, Row2, Row3 e.t.c. serially to a generic printQ. This works fine in classic 2009. My first variable, Row1, contains a printer namn, LINT1, but after leaving NAV it contains “crlfLIcrlf.NT1” (.=space cr=carridge retur, lf=line feed). Im having good help from local consultans and colleagues but now we are stuck. Tried everthing now so all help is appriciated.
Hi B52,
So you “tried everything”. But exactly what did you try??
Normally this works fine by assigning the LF+CR to a char variable. Did you try that?
Thanx Erik for your reply.
The problem is now solved by changing the font to currier!
:slight_smile:
