How can I prevent the printing of attached notes weither in Sales or in Purches .
I’ve added a check box to Docuref Table, i’d like to print the note only if that check box is thicked.
Thank you in advance.
You have a setup which does this.
In AP → Setup → Forms → Form Setup → Purchase order tab → Include document on sheets to None
In AR → Setup → Forms → Form Setup → Confirmation tab → IInclude document on sheets to None
In AX 2012 the setup will be available in Procurement.
Kranthi, first of all, Thank you for your prompt reply,
I’ve added a checkBox in DocuRef table : Sales Order
I select a sale Order, I go to Attachement then I create a simple note, If I thick the check Box, the note will be printed in the invoice. otherwise nothing to be done.
Thank you.
You can extend the existing implementation, which i have explained earlier.
You could have used the inbuilt internal and external differentiation which is out of the box.
Thank you guys !!
