Printing a Report to a File
Hi, I keep bugging you guys. But I want to create a file from a report. I know you can do that by setting up a printer driver for a specific report and define it as a file output. The problem is, that I can’t specify a filename. Other option would be to use ‘File’ as a datatype. Any suggenstions what would be the easiest way to do this? Roelof.
1 - Create a printer (Generic text Only or other depending on your need) in the printer folder 2 - Modify the printer properties, use FILE as output port. When you print to this printer, Windows ask you for a filename. Best regards, JML
