Does anybody print 2 checks on a Legal size paper stock (14")? I was trying to adjust the report manually but because check stub has different number of lines it is hard to get the check printed on the same spot all the time. We will purchase the report for a reasonable price. Thanks
Did you try Setting A MaxIteration? Use this property to set a limit on the number of times that a data item will be iterated when the report is run.
