Please Nav Community , could someone help ,I’am adjusting report in NAV 2016 and I have one object with RDLC built , with "word print " functionnality , data is displayed in paper header and footer , even adjusting margin report properties nothing is changed.
You can get follow a complicated procedure, but i would suggest you to copy the text from the header and footer and paste it in a fresh document page. Else you can just disable the footer and header
Please could you provide more detail , just for remark it’s that a commun issue for all the community that saving in word is not considering margins parameters ?
Ok then that’s what you get! No way to change it (except maybe some extreme work around).
Using the function to save to word is like running the SAVEASWORD command.
And the SAVEASWORD are generally just as useless as SAVEASHTML or for that matter SAVEASEXCEL. It tries to save it as a file in that format as good as it can, but it almost never look the same as the original report.
If you need a report which you can save to Word and be able to control stuff like headers/footers etc., then the only way is to create a specific Word Layout for your report. You are using NAV 2016, which was the version this feature was introduced (or was it NAV 2015).
Your explanation is very intersting and logic , it will be a needful post for a lot people going from Nav 2009 to Nav 2016 ,after many research I was thinking same and I would like to confirm my inderstanding,
Thanks a lot again Erik , it’s pleasant thing your sharing and help,
