I need a solution to print pdf file which is already imported as a blob in navision. There can be mulilple pdf files which can print at a time (default printer).
I have done my investigation and came across some wonderful solution like
Root := Filename
SHELL(’“C:\Program Files\Adobe\Acrobat 7.0\Reader\AcroRd32.exe”’,’ /p /h ',Root);
but the problem with this solution is that if another client has acrobat 8 installed it won’t work.
I have seen pdfcreator but i just need to print pdf document not convert or anything.
I am using window Vista
Any help would be apprecialted. Thanks
If you want to code your solution anyway, why not store the “path_to_pdf_reader(maybe_with_exe)” in the user profile (add a text variable) and use the shell command then?
This could be useful. Be sure to use automation objects of the type ‘Microsoft Shell Controls and Automation’.
PrintFile( FileName : Text[250])
CREATE(objShell);
IF NOT EXISTS(FileName) THEN
EXIT;
SplitDirFile(FileName,Dir,File); // nog te schrijven
objFolder := objShell.NameSpace(Dir);
objFolderItems := objFolder.Items;
objFolderItem := objFolderItems.Item(File);
objVerbs := objFolderItem.Verbs;
i:=-1;
REPEAT
i+=1;
IF i<objVerbs.Count THEN
objVerb := objVerbs.Item(i);
UNTIL (STRPOS(UPPERCASE(objVerb.Name),‘PRINT’)>0) OR (i >=objVerbs.Count);
IF i<=objVerbs.Count THEN BEGIN
objVerb.DoIt;
END ELSE
ERROR(‘Could not print file %1\Make sure you use a file extension you can print from Windows Explorer’, FileName);
