Price change for the group of customers
Hi, please, help me, I am desperate[:’(]. I do not know **what to do >>**changing the prices of all goods in MS Dynamics NAV for a group of customers: Large customers.<< Someone good to advise???[:$] [:)]
Hi Melanie,
Welcome to the user group. Well you question is not easy to answer unless we know exactly which version you are using and how your system is configured. Because if it is not already configured the right way, then the answer is not likely to be answered very easily, unless someone actually sees your system.
But assuming that your system is setup correctly (at least for what you are asking - maybe this was not an issue before), then it is to be expected that you have a setup where the group you want to update the prices for as all in the same “Large customers” price group, which is setup on the customer card.
Then you can go to the Sales & Marketing department and then use the Sales Price Worksheet, in the worksheet you use the function to either make new prices based on their previous price list or based on the current sales price calculated on the item card.
Using these functions have different calculation methods which allow you to adjust in different ways, including rounding etc.
After it has calculated the new prices, then you can manually check the suggestions, before you implement the price changes. Which again can be selected not to start until a certain date.
Thank you very much for detailed explanation.
But my task is more complex I think. I need to change the prices of all goods at once for large customers. Not change the price for only one product. Perhaps it is using the dimensions? I created a dimension of all goods, but I don´t know what to do next. And I work with version 5.0., but mainly I need to logically understand how to apply the change in prices of all goods at once for a large group of customers.
I apologize for my English.
Kind regards
Melanie B.
There are numerous ways to store prices in Navision. FIrst step would be to explain where you store prices and what version of Navision you are running.
Kind regards
Melanie B.
