On the All Purchase Order list page when you click it will open the power view to analyze the data base on analysis cube i want to use functionality Martin.
Martin thanks for your reply.
I have another issue when i run any SSRS report working on Analysis cube it is asking for user name and password. This user is the admin user and it has all rights. The standard SSRS reports are working fine only the issue is with the reports with Cubes. Can you tell me where actually i need to give access to generate reports.
It sounds like a different topic than what belongs to this thread (“Power View Installation and Configuration”), therefore you should create a new thread instead.
Martin sorry but the issue is the same when i run the anaylze data button it gives me same error “The Accounts receivable cube, which this report uses as a data source, has not yet been deployed. Deploy and process the Accounts receivable cube and then run this report again.”
