When we posting Warehouse Receipt, there is a condition that:
If Posting Date in the Purchase Order is blank or earlier than Posting Date on Warehouse Receipt, then the Posting Date on Purchase Order is set equal to the Warehouse Receipt.
Code: Select all
Codeunit 5760 Whse.-Post Receipt
InitSourceDocumentHeader()
WITH WhseRcptLine DO BEGIN
CASE "Source Type" OF
DATABASE::"Purchase Line":
BEGIN
IF (PurchHeader."Posting Date" = 0D) OR
(PurchHeader."Posting Date" < WhseRcptHeader."Posting Date")
THEN BEGIN
PurchRelease.Reopen(PurchHeader);
PurchHeader.SetHideValidationDialog(TRUE);
PurchHeader.VALIDATE("Posting Date",WhseRcptHeader."Posting Date");
PurchRelease.RUN(PurchHeader);
ModifyHeader := TRUE;
END;
The problem is:
If someone create a new replacement Purchase Order on 10/25/13, but the Warehouse Receipt must posting on 10/24/13, then the Posted Purchase Receipt is posted on 10/25/13, although the Posted Warehouse Receipt is 10/24/13.
It could be a problem, when the first Purchase Receipt is using later Posting Date, than the second Purchase Receipt (not make sense in real scenario, but this could be happen when there is an erroneous in first Purchase Receipt).
I have tested posting it using:
Inventory Put-away, and
Purchase Order
and all other way is resulting in Purchase Receipt with Posting Date of 10/25/13.
Does anyone know, if it is a known bug, or any logical reason behind this work-as-design?
Thank you.
