CANNOT edit date in the Inventory Adjustment ‘Lines’ but can delete posted inventory lines and journals bot – ref Inventory Journals (Inventory Management > Journals > Inventory Adjustment)
I believe once the transactions have been posted, AX must not let anyone edit and delete records. Kindly advise.
Examples: Deleted posted record in Inventory - IJ00000035 does not exist anymore.
AX will allow you to delete the posted journals. Deleting journals will not delete the related inventory/financial transactions, you can still see them from the product - inventory transactions.
You also have an option to delete the journal lines immediately after posting the journal (Delete lines after posting → on journal names)
Thanks for the response Kranthi. I have three queries subsequently.
- How do I edit dates on a posted journal lines as a result of clerical error on the dates? Only option is to deleted and recreate journal or is there any way to correct the posted journal line date (ref Inventory Adjustment)
- Please can you help me identify where to locate above deleted journal?
- And I guess you referring to below ‘Transaction’ (Inventory Management > Inquiries > Transactions > Transactions ??
