Hi to all, I need very urgent a complete file (text or xls or ???) with all actual postcodes and related cities of England, to import it to Navision. Is there anyone who can send it to me? Or any suggestions / recommendations? Thx in advance. Rolf
Try www.royalmail.com Good luck!
Not sure whether this affects your situation, but you may want to bear in mind that UK postcodes are constantly changing, so you will end up constantly updating the info in Navision with updated and deleted postcodes. If this is an issue, you are probably better off integrating with the PAF from the above RoyalMail link (or www.qas.com), which should (in past experience) be quite quick to do. If it is not an issue, then never mind! Regards, edd
Dear friends, I can’t get or find the postcodes from royalmail, and so on. Or show me the way how to do it. Another way: Is it possible, someone from UK, who has the postcodes inside in Navision makes an export from T225(Postcodes) with a dataport and sends it to me? Please help me. Thanks from Germany Rolf
Hi Rolf The data section is here: http://www.royalmail.com/portal/rm/jump2?catId=400145&mediaId=400084 Or use Edwards reference. You do have to pay for this information. Orwait and see if some kind person sends you a free list (I don’t have one [:D])
