hi, is their any way to get the optionstring of an option field ? i thought about a system-table or anything else but didn’t find anything … *** quack ***
It’s possible to have more information please
okay i have some option fields in my table and for a user-search formular i want to give the user a selection-help … so i need to read the current optionstring (all the possible values for this field) out of a option field and put it in a text-variable … *** quack ***
If you want to put the current value of the option field use the “FORMAT” function TXT:=format(OPTIONField);
thx but i don’t want the value … i want the text stored in the property: optionstring of the option field … *** quack ***
in a form put the optionstring propertie non editable
mmmh i don’t think you understand me … i have a textbox as optionfield which drops down an lets the user choose out of its values which are stored in its property optionstring … so now i want to get this options string (the comma-seperated string and not one value!) using some code … should be look like this : txt := field.optionstring() and in txt should be shown something like value1,value2,value3,… and so on … *** quack ***
If you know the number of options in the option string then run through the values formatting each one.
FOR i := 0 to N DO BEGIN
Record.OptionField := i;
OptionString := OptionString + ',' + FORMAT(Record.OptionField);
END;
OptionString := COPYSTR(OptionString,2);
Edited by - Jack Reynolds on 2001 Dec 13 13:59:55
