Hi Everybody,
I have an issue with splitting of quantity in Direct Delivery process.
I created a SO & PO by direct delivery process, when i try to split PO line quantity (PO Line → Inventory → Registration → Split)
i get error saying that “There are transactions with status Reserved ordered for the dimension of item ->Consequently inventory dimension cannot be changed.”
Item is serial number activated and i want to split PO line quantity with difference serial numbers.
Above issue raises only in case of direct delivery PO, in normal PO i can split qty by changing serial number.
How can i split qty by changing the serial number in Direct delivery process?
Please help me if anyone has solution or suggestion.
Rajendra
