hi,
Can i know how to delete purchase order invoice lines
hi,
Press the red cross. If the AP parameter on invoice update is Error however it will not let you. Deleting them also does nothing to the transactions.
I can see delete actions has been set as well as delete method overridden in PurchLine table. Suggest to test this thoroughly in a test system
Not a problem. you can delete them until the safety level is not Locked as Adam said.
There are some other parameter which will do it automatically like “Delete purchase order lines invoiced in total” and “Delete purchase order after invoicing”.
hi,
deleting lines of a sales order with status invoiced, does not however effect the inventory,
but u can do this by checking a parameter,
Navigation :: AR > SETUP > Parameters > Update > Invoice > delete order lines…
