Ø Why Cross- Reference Used?
Ø What is Application Hierarchy Tree?
Ø What are the applications used in AX it wil run in client side or Server side ?
Ø What are the Customizations to live Applications in AX ?
Ø What is the Pack and Unpack definations?
Ø .why Select Statement used in Query Only and what are Query, Query, Query Run, Query Build Data Source, Query Range?
Ø what is the difference between the Auto Report and Generated Report?
Ø What is the use of Synchronization in Ax ?
Ø what is the Map?
Ø what is the difference between Serilization & non-Serilization?
Ø what is the Polymorphism? how it works in AX?
Ø .what is the function overloading & function overriding?
Ø Can you just tell the table properties that you can remember?
Ø What is cache lookup what is it used for?
Ø Different types of relation? Explain it detail?
Ø Explain OCC & PCC (optimistic concurrency control , Pessimistic concurrency control)
Ø Difference between views and tables
Ø Explain Queries? What’s it used for?
Ø Explain different types of reports?
Ø Differentiate auto design spec & Generated design? Which one is a preferable choice and why
Ø Primary Key in tables (In dynamics AX don’t have primary key)
Ø Explain primary index and Cluster index? Explain in detail?
Ø What is the default index for a table?
Ø Explain delete action? Types of delete action?
Ø What are all the add- on tools you used in Dynamics AX (It’s an indirect question for AIF)
Ø Did you work with EP (Enterprise Portal & Workflow) how can you implement this features into your projects
Ø Can you just point out some best practice you used when u develop a project?
Ø Did you worked with base modules? Actually I answered this question as
Ø I worked with production module to integrate with our steel process management
Ø So can you just point out three classes that you used in production module
Ø Explain the posting in production module
Ø When you create production order….Can you point out the affecting classes, tables.
