Planning Worksheet - MRP is blank / Business Central
Hi, when i run the planning worksheet its only showing for the MPS and not the MRP (blank). I went back to the item card and made changes (i have my replenishment section filled out with Routing and BOM + Order Policies filled out) = still blank. I also created a demand forecast = still blank.
Please help.
Sara.
Do you have location mandatory setup - part of inventory setup
If so fill in components at location value (your main location) and retry
By the way we always turn on location mandatory as a best practicešŸ˜€ - let me know
Best Regards
John Grant
Innovia Consulting
Hi John, i do have location mandatory setup. I did retry and got some new output: But the purchase order do not have a ref.order.No - which means i cant accept the action message?
I am testing this out in the chronus company beforehand in order to teach it afterwards.
Sara,
What Reordering Policy are you using? Not all policies will fill in the Ref. Order fields. Also, if you aren’t getting a suggestion, a Reordering Policy is required for the Planning Worksheet to make suggestions for the Item.
Regarding the Components at Location field in the Manufacturing Setup, if you only have one (1) Location then populate this field with that Location. If you have multiple Locations, it is better to leave it blank and Create Stockkeeping Units for the different Locations.
Regarding the Forecast, be sure you have ā€œUse Forecast on Locationsā€ enabled.
Hope this helps!
Ben Baxter
Accent Software Inc
Hi Ben,
Thank you for the reply, i am using Prod.order as my reorder policy. I always remember to fill out the Reordering Policy on the item card. I only have one Location set up right now.
I will try your input regarding the ā€œUse Forecast on Locationsā€.
Check item card settings for MPS and MRP. Verify Routing, BOM & Order Policies. Review demand forecast. Check planning worksheet filters. Contact support if needed.Verify item card settings, demand forecast, and worksheet filters. Regenerate worksheet if necessary. Seek technical support if problem persists.
