When I manually create a picking list, I can drill down the lot number field as below:
Just wonder where the records from the drop down list are from?
Based on the Item BOM?
You have already created the pick journal, this lookup references the existing lines, these are the original transactions with estimated and remaining elements. You can add it to teh existing inventory transaction so on the analysis reports the two pick lines are combined rather than separate.
Where can I inquiry these transactions without looking up from the Lot ID field?
Look at the picking list journal lines or from each item - but the lot id is the identifier for the transaction.
