Picking list for transfer order and inventory adjustment journal
Hi There
Since i enable the picking requirement in the item model group anything that is took away from warehouse should be picked first before you can post the transfer order or the inventory adjustment journal.
Here the warehouse staff’s role is quite simple, they give the product when they see the picking list. is there a way that i can print above picking list without customizing the system?
many thanks.
The transfer order has a picking note as standard. The adjustment needs the line to be set to picked - there is no document except the print out of the journal, so use that.
