Does anyone know of a free or cheap PDF printer application that supports Server 2003?
We were trying to use Acrobat but aparently it does not support Server 2003. We want to install it on our ERP server for one or two home users to use via Terminal Services to print PO’s to PDF files and e-mail to vendors.
We are using ZEON PDF which is not free but works quite well. You can generate PDF’s unattended as you are able to tell the driver what file name to use for printing. If you need more info just reply.
Kevin, We have also successfully used 995. I can’t say with certainty we’ve had it installed on server 2k3 but wouldn’t hesitate to give it a try. Brad
