I get an error message when I try to “Calculate” in the Payroll Journal. I get the following error (and when I test this in Cronus with the canned brackets that come with Navision I get the same error): There is no Bracket Detail that matches the filtering information: Bracket Code: Bracket Type Code: Bracket Effectice Date: Activation Code: Reporting Authority Code: Filing Status Code: Employee No.:MFD Payroll Control Code: NYC-RES Run Employee Pay Control - Test on the Employee to verify the Payroll Control Codes. I ran the test and everything looks ok. I don’t know where to go from here.
I am curious if you resolved this problem. I am having the same error message and everything appears to be setup correctly.
