I struggling on how to send a check to refund customer rebates as mentioned in the tech net.
In tech net I have found this : Rebate ─ The Rebate type is typically processed by sending a check to the customer or by deducting the rebate amount from the customer’s invoice.
Rebate related material is not that good in Technet.
As per rebate agreement, once the rebate is generated, go to the customer master and in open transaction editing form, there is option for processing rebate. Click on the function button, either you can pass it to AP (In that case vendor should be attached to customer) or you can pas credit note.
Also, there were some hotfixes related to rebate, i am not sure how much that will be helpful. Checkout the hotfixes also.
“A rebate agreement with a rebate program type (defined by rebate program ID) “Rebate” is required to have a payment type of “Pay using Accounts Payable” (Which used to be called Check) or “Customer Deductions”(which in effect is a credit).” (http://blogs.msdn.com/b/axsupport/archive/2013/02/26/rebates.aspx) in this article I understood that sending a check is by using AP to pay back a client. Thanks
