Hi, I have a problem, I need to create a PDF file using Adobe Acrobat 7.0 Professional. I don’t know how to set the path where I want to generate my file from Navision 4.0. I can set the path in the printer Adobe PDF, but I prefer to create a setup form in Navision and to choose the directory name where I put then PDF file. Thanks in advance
If you’d like to consider an add-on to take care of this for you, we offer such a product. You can view the product information site at http://www.altusbusinesssolutions.com.
Thanks but I need only a little information, which automation of Adobe I must use to set the path where I write the PDF file generated from Navision.
