passing value in Edit method
Hey any possibilities to pass the value in Edit method??
Again, could you please provide more details?
possibilities of passing value from any method to edit method… Lets take if i need to pass a value 5 from task () method or modified()…If its possible??
Display and edit methods are normally called by AX kernel, when the value is going to be displayed.
You call edit method as any other method, and pass parameters as to any other method, it’s highly unusual. It should be a warning sign for you, suggesting that your technical solution may be designed incorrectly. Unfortunately we can’t offer any better solution if you don’t tell what you’re trying to achieve.
