Hello, friends
I need to extract the value form the field identificationText of system table PrintMgmtIdentificationText. The table have method find which returns the identificationText value. However, the method has parameter ParentId which is one of the tables fields (Please see attachment). The field have many values but its not a container type as well. It seems from the table code that the field value of ParentId is somehow constructed from RecId values.
It would be nice if you could explain what is the ParentId and how its constructed.
public static PrintMgmtIdentificationText find(
RefRecId _parentId,
LanguageId _languageId ,
boolean _forupdate = false,
ConcurrencyModel _concurrencyModel = ConcurrencyModel::Auto)
PrintMgmtIdentificationText printMgmtIdentificationText;
printMgmtIdentificationText.selectForUpdate(_forupdate);
if (_forupdate && _concurrencyModel != ConcurrencyModel::Auto)
printMgmtIdentificationText.concurrencyModel(_concurrencyModel);
select firstonly
where
printMgmtIdentificationText.ParentId == _parentId &&
printMgmtIdentificationText.LanguageId == _languageId;
return printMgmtIdentificationText;
Kind regards,
Roberts
