"Parameter _reportName cannot be null or empty".error while opening any report
compiled and now no more error ! thanks for the help . =)
Hi abbas,
send me the same document plz.
this help me, just needed to compile the node of clases in the aot.
Hi everyone,
I am very new to Dynamics AX. Would it be possible to get the document posted on here somehow? I am having the same issue and would appreciate it a lot!
Best,
Kate
Actually I just tried what Franciso suggested and compiled all the classes of the AOT. It took like 30 minutes to compile, but it fixed my issue. :smiley:
Thank you!
Hi Jenny ,
Is your problem is solved.
sudha[Y]
yes. long tym ago.
but i didn’t do anything.
mayb someone else in my team solve this…[:)]
Hi Jenny,
Can i know how it is resolved.
Thanks in Advance,
sudha
Hye Sudha,
Its related to SRS report which im not familiar with…
You should ask this to someone expert.
I am sorry, i couldn’t help you.
I have same problem Please Can you give any idea urgently?
Thanks for your help.
Parameter _reportName cannot be null or empty.The [CLASSNAME].METHODNAME reflection API could not create and return the SrsReportNameAttribute object
In this specific case it looks like an earlier full compile did not finish.
If you encounter this problem I would suggest that you first compile the class mentioned in the error message and see if this solves the problem.
  1. go to AOT (get Ctrl+D)
  2. in Classes find CLASSNAME
3.compile it (F7)
HI all,
Just start compile for classes…it may solve your issue for reports…
i have done same.
Thanks and Regards
Ramandeep Chauhan
Can you please share the document , me too facing the same issue
Hi Abbas can you please send me this screen print out
As I am not able to view any report in dynamics and getting this error message
Parameter ‘’ cannot be empty.
The LedgerTrialBalanceDP.getAttribute() reflection API could not create and return the SRSReportParameterAttribute object. Please check the parameters.
very much appreciate your help
Hi Jahenzab,
Screen shots which i have provided before may resolve but that is not best practice. So please follow the below steps will definitely resolve your issue,
  1. Do Full CIL and remove report cache in tools → caches → refresh report server
  2. redeploy the specific report by using power shell
Do let me know incase if it didn’t work well.
Br Abbas
We have AX 2012 R2 CU7. This is issue happen to all the report in AX. This way works for us.
  1. Full Compile
  2. Restart AOS
  3. Clear cache in AOT
  4. Restart reporting service
