You need to show the columns “Previous Operation No.” and “Next Operation No.” and use these. For example you have operations 10,20,30 & 40 where 20 & 30 are in parallel then set it up as
Can you also tell me what does it mean by ‘operation is calculated’ posted in my origianl Question?
Ok. I have setup my parallel operations according to you example. Now where does it make the diference as opposed to using the ‘Serial Type’? Is it on due date and time on routing lines for the Produciton Order?
It will have an impact on due data, if the two operation are parallel then it will take lesser time. You can try doing the same thing serially and parallel and do the calculation of Due Data and see the difference for yourself.
