Page break in html is wrong
Hi all. Has anyone found a way to print html reports on laser so that page break, or the header, fits on the top of the page. For example run report 715 (Price list), save it as html and print it on paper. I have two lines at the top of page 2 and a header under it. Hope someone has found the solution. Regards Gudmundur Petursson
As of current versions <=2.60, i think you will have to generate your own HTML code to have full control. Check out the download section at www.mynavision.net, there is a HTML thing you might find useful. Soren Nielsen, moderator Integration/Developer NOLUG
When you save as html Navision converts a report to HTML using tables… so formatting can be very difficult to achieve perfect reports for both printed and HTML converted reports. Often things are not lined up perfectly on reports but look as they should when printed, but this complicates the tables tremendously. Also, the SAVEASHTML code and the Save as HTML Menu probably use different code version, just as the MAPI functions use different code to the Send… menu option. Craig Bradney Technical Manager Navision Solutions & Services, Deloitte Touche Tohmatsu Email:cbradney@deloitte.com.au
