Client is running Microsoft Dynamics NAV 2013 R2 (7.0.46057.0)
When running the plan this error shows up on the item:
Overflow under conversion of Microsoft.Dynamics.Nav.Runtime.Decimal18 value to System.Int32.
Has anyone seen this error before when running the planning worksheet?
From using google other people has had this issue as well but noone when using the planning worksheet,
From researching the “code” this issue has something to with the calendar and that the “time” is somehow wrong, but even changing the routing to 0 time gives the exact same error.
Thanks in advance,
Soren
