Other users problem.
Hi all, I installed the navision attain client on a server. (this server will be a terminal server). I installed it when I was loged in as an administrator becouse that is how things go. Administrator accounts are the only accounts with install rights. Now the problem is when log in with a difrent user I can not run navision attain. It just starts a quick setup and fails immediatly. I thought When I give exe rights to an account that they should be able to run it. And I’m not planning to give TS users admin rights to run Navision attain. best regards.
Hi Roel, See http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=7779. I had the same problem and used the suggestions there. It works. esso
