Order Promising
Hi Experts,
I got a transfer Order for an item which is sceduled to receipt on Jan 20 in a Particular Location.
In my Sales and Marketing → Order Promising setup → Offset (time) is 1M.
I enter a sales Order On Jan 1st (same item/ Same Location) thinking it would consider my transfer in Jan 20. Still i get a stock out message and i notice the date filter in that message is still set to this Sales order date where as it should look in one month ahead from my Sales Order.
how do i make this happen?
(I do not use manufacturing module but use the SKU. This is Navision 4.0 SP3 - Native)
Thanks a lot!
For Order Promising u need to check
Field on Company Information card i.e. the bucket time keep it as month atleast to see the effect in ur case. Did u calculate available to promise first than capable to promise ?
Appreciate your quick response.
I did test on those check marks on company setup and does not make any diference.
I am not calculating the order promising. Instead im entering the SO lines Manually. Is there anything wrong with that?
just to add one more thing…
In the stockout message the ‘Earliest Availability date’ is blank…
As the title of the post said I assumed u might have used Order Promising. Is the location on Sales Order same as the receipt location on Transfer Order and what is the receipt date on Transfer to tab of Transfer Order.
If location are same and this inventory is not committed at any other place then the earliest Availability date will be same as date on Transfer to tab’s Receipt date.
Addition: once u check all this then run Order promising and see what date system suggests u.[:)]
