What is the meaning of Order error tolerance in AR setup form ?
Thanks in advance
Thanks in advance
which version? which tab?
AX 2009 or 2012 - > AR Parameters - > Summary update tab
Select the type of message to be displayed when orders are summary-updated and do not match the criteria set in the Summary update parameters form:
Seems pretty straight forward from the help - basically you are summary update, the batch criteria contains elements it cannot summarize by and this is how you handle those.
