Order by on multiple columns in grid.
I would like to have order by on multiple columns in the grid. Can anyone of you suggest me how to do that?
Thank you.
You’re in a developer forum. Are you trying to write code for sorting?
Once you make a column order by, it would effect all the remaining columns of the grid accordingly, So logically it seems not possible.
Yes. I would like to sort grid basing on multiple columns through code.
For example :
Name class rank
Giri 1 2
Shekhar 2 1
Mani 2 3
Praneeth 3 1
Prasad 3 2
Now i need to sort the grid by class descending and rank ascending.
output
Praneeth 3 1
Prasad 3 2
Shekhar 2 1
Mani 2 3
Giri 1 2
It’s easy - use QueryBuildDataSource.addOrderByField() multiple times.
For example, you could put code like this to datasource’s init() method:
this.queryBuildDataSource().addOrderByField(fieldNum(MyTable, Field1), SortOrder::Descending);
this.queryBuildDataSource().addOrderByField(fieldNum(MyTable, Field2));
Thank you Martin. It works…[Y]
