Dear All!
Can you tell me how to calculate opening balance of item in AX?
Thanks in advance!
Dear All!
Thanks in advance!
What do you mean?
Are you trying to create the opening balance? Use an item journal to do this.
I want to select opening balance of item by accounting period. It can be in the past.
Thanks a lot.
You want a report showing you the value of inventory at a set date?
I want to showing inventory include (opening balance,increase, decrease…) in a set date.
Thanks a lot.
Nope there is not a standard report in this format, you would need to write one to produce this.
