I’m new on Axapta.
Have you any idea about to start different Reports from a single Menu item: I need this because I would like to open different custom reports (ie SalesInvoice) based on Company.
Thanks for help
I’m new on Axapta.
Thanks for help
you can simple assign the menu item to a class instead of a report. and in the class, depending on whatever you want, open different reports.
Hi Vanya,
thank you for your answer.I check your solution and I work on reportRunClass method of ClassFactory class.In the following code you find my solution.
ReportRun reportRunClass(Args args)
#AOT
str reportName = args.name();
str reportNameNew;
Report tmpReport;
TreeNode reportNode = TreeNode::findNode(#ReportsPath);
// if a report called exists run it
// otherwise run the standard one
reportNameNew = curext() +’’ + reportName;
tmpReport = reportNode.AOTfindChild(reportNameNew);
if (tmpReport)
args.name(reportNameNew);
return new sysReportRun(args);
Please let me know if in your knowledge this is ok.
Thank you again!
Well, actually I was thinking there are only a couple of reports like that, and was intending for a more “local” solution, with a separate class launching reports, but I guess this is Ok and should work as well.
And if you have a lot of reports that have to be Company_based, than it’s the perfect way to do it, I guess.
Minimum changes
Thank you very much!
