Can anybody give solution for the below mentioned issue
Issue: User has created new journal selected the line button and then created another new journal, selecting lines button but lines button has disable.
if suppose close the 1st journal user can able to go to 2nd journal lines otherwise he is not able select the line button.
If I select another journal (I’m currently working with an item journal), the form with lines refreshes and shows lines for the newly selected journal. That’s normal behavior. User can open multiple form with journal headers, if needed.
I don’t think that will open a new journal lines form, instead it will close the existing one when you click on New button and then enables Lines button to open journal lines form again.
So the only point to have multiple journal lines open is to have their multiple headers open as well. Correct me if I am wrong.
The exact issue is there is 10 journals with lines
i have selected the 1st journal > lines >minimized the lines form then i went 3rd journal >try to select the lines button but lines button is disable, because 1st journal & 3rd journal opened by same user and 1st journal locked by user so same user can’t open another journal until close the 1st journal.
is there another alternative solution to open more than one journal at a time by same user.
Why do you need to click on Lines button? To see the journal lines correct?
When you move to 3rd journal and open the minimized journal lines form what does it show you? It shows details of 3rd journal but not 1st journal right? So it doesn’t really matter if it is 1 journal or 10. All you need to see is whether the journal lines is showing correct lines while you focus to another journal in the list or not. Which it does.
If you want to see all journal lines at once they may be you can go for multiple journal forms as well.
