One form, Two workflow types
I need to create two workflows to use on the Sales orders form; one for Sales order approval, and another for credit limit approval in case of a credit limit conflict. i will add the latter as a subworkflow of the first.
however i can only choose one workflow type on the form design. is that a mandatory step? or can i skip it for the sub-workflow type?
any other suggestions are appreciated.
Hi Rola,
Have you figured out how to deal with this scenario?
I have similar problems to solve and I have no idea how to give multiple workflowType names to the SalesTable form property now.
Thank you,
Kwen
Hi Rola,
I believe that you can use the following code to achieve your requirement.
The below code must be written in init() method of the form.
if (conditionA)
element.design().workflowType(‘WFType1’);
else
element.design().workflowType(‘WFType2’);
Hi Kwen,
if (conditionA)
else
