One dialog value depend for next dialog lookup
Dear Fnds,
I have customized customer releated report , in that i have done two dialog fields,1.cust group and 2.custa account
in first we are choosing AP-DD means second dialog has to lookup only that custgroup but not happening this that , So some one help me. for your reference i have given the my codings also , where i did mistake plz help me.
public class ReportRun extends Runbase
DialogField TestDialogFields,emplIdField,dialogByDate,dialogToDate,dialoginvoice,myPackingSlipIdField,myLineOfPackingSlipIdField;//,dialogstate,dialogAccountNUm;
fromDate byDate;
fromdate toDate;
packingslipid myPackingSlipId;
tempinv tempinv;
DialogField dialogcustGroup,dialogcustaccount ;
CustTable obj_CustTable,obj_dev_CustTable ;
custaccount CID;
//CustInvoiceId id;
DialogField dialogCreateServiceOrders;
NoYesId createServiceOrders;
CustAccount custAccount,v;
custgroupid custidg;
//ueryRun queryRun;
#define.CurrentVersion(1)
#define.version(1)
#localmacro.CurrentList
createServiceOrders
#endmacro
//variable
int sno,pge;
real unitprc,linamt,invamt,linedis;
itemid invitem;
inventbatchid getInventBatchId;
inventqty qty;
CustInvoiceId invid,oldinvid;//,id;
invoicedate invoicedt;
SalesEndDiscPct TotDisper;
SalesSumLineDiscAmount disc;
SalesSumLineDiscAmountMST disprc;
transdate lrdt;
lrno lrno;
Transporter trp;
VehicleNo vno;
//Tabele
CustInvoiceJour custinvoicejour,jour;
CustInvoiceTrans custinvoicetrans,trans;
InventReportDimHistory inventreportdimhistory,dimhis;
Inventdim inventdim;
real cqty,invqty;
salesId salesId;
//MarkupQty oqty;
boolean isSummaryUpdated;
str lineHeaderPrinted[];
int lineHeaderPrintedCount;
container inventDimSetup;
InventDimCtrl_Rep_Sales inventDimReport;
str inventDimString;
boolean paymentSchedule;
boolean printDocuHeader;
boolean printInventDim;
PaymentStub giroType;
PrintCopyOriginal printCopyOriginal;
ReportSection giroSection;
FirstLast totalsFirstLastPage;
boolean taxPrintTaxFreeBalance;
boolean showFooter;
boolean showFooterPayment;
boolean showFooterEuro;
boolean showFooterPrepaid;
boolean showFooterPrepaidEuro;
boolean showFooterGiro;
boolean showFooterLocalCurAmt;
CustFormletterParameters custFormletterParameters;
CustFormletterDocument custFormletterDocument;
CustParameters custParameters;
CompanyInfo companyInfo;
Map sectionEnabledMap;
PaymMoneyTransferSlip_BE moneyTransferSlip_BE;
PaymMoneyTransferSlip_CH moneyTransferSlip;
ReportStringControl paymentReference;
//Italian feature
boolean goodsDiscount;
DiscPct LineDiscount;
ReportTextControl reportTextControl;
PaymMoneyTransferSlip_FI moneyTransferSlip_FI;
container taxCodesUsed;
TaxTexts_FI taxText;
MarkupTrans markupTrans;
MarkupTmpTrans_FI tmpMarkupTrans;
TaxCode taxCode;
TaxGroup TaxGroup;
boolean custCreditInvoicing;
CustVendCorrectedInvoiceId correctedInvoiceId;
CustVendCorrectiveReason correctiveReason_header;
CustVendCorrectiveReason correctiveReason_lines;
AmountMST originalInvoiceAmount;
AmountMST originalInvoiceVATAmount;
boolean cashDiscOnInvoice;
DiscPct cashDiscPercent;
CashDiscAmount cashDiscAmount;
CashDiscAmount cashDiscAmountTax;
Amount amount;
Amount GrossInvAmount;
boolean isTaxInvoice;
ItemType taxInvoiceItemType;
AmountCur totalSalesBalance;
AmountCur totalDiscount;
AmountCur totalMiscCharges;
AmountCur totalSalesTax;
AmountCur totalRoundOff;
LedgerJournalTrans ledgerJournalTrans;
TaxUnrealizedPayment taxUnrealizedPayment;
RefRecId invoiceCount;
SalesLine salesLineRegNumbers;
int a;
str lic;
//Tables
InventTrans inventTransLoc,inventTransCheck;
Address address,partyAddress;
InventSite inventSite;
// InventLocation inventLocation;
DirPartyTable dirPartyTable,custPartyTable;
//InventDim InventDim;
//EDT’s
ItemId getItemId;
//InventBatchId getInventBatchId;
TransDate getBatchExpiryDate;
Qty salesInvoiceQty;
Amount salesPrice,SalesNetAmount;
Description itemDescription,cropDescription;
Qty packingUnitQty;
ItemId gloItemId;
//Integer sNo;
#Define.endDisc(‘CustInvoiceJour_EndDisc’)
#Define.sumMarkUp(‘CustInvoiceJour_SumMarkUp’)
#Define.sumTax(‘CustInvoiceJour_SumTax’)
#Define.invoiceRoundOff(‘CustInvoiceJour_InvoiceRoundOff’)
#Define.invoiceAmount(‘CustInvoiceJour_InvoiceAmount’)
#Define.currencyCode(‘CustInvoiceJour_CurrencyCode’)
public void dialogPostRun(DialogRunbase _dialog)
// super(_dialog);
_dialog.formRun().controlMethodOverload(true);
_dialog.formRun().controlMethodOverloadObject(this);
public Object dialog(Object _dialog)
DialogRunbase dialog = _dialog;
DialogGroup toFromGroup;
Args _args;
str accountnum,custGroup;
custtable custtable;
custGroupid id;
dialogcustGroup = dialog.addField(typeid(CustGroupId),CustGroup,“CustGroup”);
dialogcustGroup.value();
dialogcustaccount=dialog.addFieldValue(typeid(custaccount),custaccount,id);
dialogcustaccount.value();
return dialog;
public void Fld4_1_Lookup()
SysTableLookup sysTableLookup;
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
Query _query;
FormStringControl _control;
sysTableLookup = SysTableLookup::newParameters(tablenum(CustTable),dialogcustaccount.control());
sysTableLookup.addLookupfield(fieldnum(CustTable, AccountNum));
sysTableLookup.addLookupfield(fieldnum(CustTable, CustGroup));
_query = new Query();
queryBuildDataSource = query.addDataSource(tablenum(CustTable));
queryBuildRange = queryBuildDataSource.addRange(fieldnum(CustTable, CustGroup));
queryBuildRange.value(dialogcustaccount.value());
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
palani
