Ohm character
NAV Attain 3.10 A German Hi, some of our items are resistors (you know: those little electronic thingis to reduce current). The description field of the item should include the “resistance” value, which usually is given in Ohm. However, entering the respective greek character did not succeed so far. I think, NAVISION cannot handle this character since it is not part of the 127dec-ASCII list and thus I need to enter the three-letter-word “Ohm” instead. Can someone please confirm. Thanks in advance. Klaus
I thought the Omega sybol was dropped years ago, I woulf have thought that a 2.7k ohm resistor was written as 2k7 [?]
Thanks for your info, David! You are right. Resistance values are written as you stated. However, we have several other components (such as BNC connectors, RF cable types etc.), which need to be described by means of “Ohm”/Omega. I used “resistors” just to make it clearer… [:)] Klaus
