OffsetLedgerDimension is not set on journal lines created using X++ code
Hi Everyone,
While I am creating general journal getting below error
and afterward, debug it and found ledger.offsetLedgerDimension getting 0, here it is getting an error
if (isConfigurationkeyEnabled(configurationKeyNum(PublicSector))) is enabled in my Ax 2012 R3. So, I disabled the Public sector configuration key it will is resolved issue finally Post the general journal.
But I knew this is not a correct way to post the general journal so please advise me…
this is my code
static void LedgerJournal(Args _arg)
    AxLedgerJournalTable        axjournalTable;
    AxLedgerJournalTrans        axjournalTrans;
    LedgerJournalTable          journalTable;
    LedgerJournalCheckPost      journalCheckPost;
    container                   acctPattern,offsetacctPattern;
    axjournalTable  =   new AxLedgerJournalTable();
    axjournalTrans  =   new AxLedgerJournalTrans();
    axjournalTable.parmJournalName("GenJrn");
    axjournalTable.save();
    axjournalTrans.parmJournalNum(axjournalTable.ledgerJournalTable().JournalNum);
    axjournalTrans.parmTransDate(systemDateGet());
    axjournalTrans.parmCurrencyCode("USD");
    axjournalTrans.parmAmountCurCredit(1000);
    axjournalTrans.parmAccountType(LedgerJournalAcType::Cust);
    acctPattern = ['110180-001','110180',2,'BusinessUnit','001','Department','022'];
    axjournalTrans.parmLedgerDimension(AxdDimensionUtil::getLedgerAccountId(acctPattern));
    axjournalTrans.parmOffsetAccountType(LedgerJournalActype::Ledger);
    offsetacctPattern = ['112000-002','112000',2,'BusinessUnit','002','Department','023'];
    axjournalTrans.parmOffsetLedgerDimension(AxdDimensionUtil::getLedgerAccountId(offsetacctPattern));
    axjournalTrans.save();
    journalCheckPost = LedgerJournalCheckPost::newLedgerJournalTable(axjournalTable.ledgerJournalTable(),NoYes::Yes);
    journalCheckPost.run();
    info(strFmt("Journal No: %1",axjournalTable.ledgerJournalTable().JournalNum));
James
You shouldn’t be disabling the configuration key for that purpose. You will loose the data related to it.
Try calling clearField method before calling parmOffsetLedgerDimension()
axjournalTrans.clearField(fieldNum(LedgerJournalTrans, OffsetLedgerDimension), false);
Thanks, Kranthi, It’s working fine now.
Kranthi, thanks a lot
