ODBC - ASP.net Very Slow
Hi, not sure if this post is still active. I am writing an ASP.net app that queries our Navision DB using ODBC. The queries are not very large and only hit one table at a time. I have a loop that perfoms a max of 20 queries, each returning approx 10 records. This query takes a full minute to execute! Seems rather long for a 200 (±) record query. Is this bad performance due to ODB. Is C/Front a better alternative?
Matt
Yes, C/Front is faster, but I would rather see if client moves to sql, and you could use SQL native drivers.
Thanks Rashed,
Converting to SQL Server isn’t an option at the moment, and unfortunately, we don’t have a license for c/front. Do you know of any other alternatives to ODBC? If not, are all custom apps using ODBC → NAV very slow? I can’t seem to find much info on this subject. Any ideas would be appreciated.
Matt
The c/front granule is not that expensive. Is there a reason you can’t add it to your license? You’ve probably spent more money chasing this problem already.
ODBC driver for native database never wasn’t very famous related to performance. C/front will use native database access. You will have a performance boost.
