How to Display Updated Number Sequence With Site and Warehouse in Purchase Order Packing Slip Report?
If you have the number sequence as part of the table you will need to add the field to the report, do you know how to do this?
Sometimes when modifying reports, I use the Fetch method to pull in the value into a variable, then write a display method to show the data (the variable) on the report.
Or if I am picking you up wrong, and you mean that you posted a Delivery Note and then edited data and want to view this, I am unsure how this is done, so sorry [:)]
