I just want to know where number sequence for ("Purchase, inventory receipt ") and (“Purchase expenditure for product”) will be taken in code while we post Purchase Invoice… i.e Invoice → voucher → 5 vouchers will be created and among 5, voucher number sequence for Purchase, inventory receipt and Purchase expenditure for product , where we have to define in the set up and which class , method is used to pick the Number sequence??
Any help regarding this will be highly appreciated
In the screen shot you can see the first 3 vouchers having same number sequence. But the last two are having different one. So your help is urgently required … Thanks in advance for your reply
I even know that class is used for voucher number sequences, but only for the first three entries , number sequence has been picked from that method… But for the last two entries, number sequence has been picked from some where else. Since I debugged that class , invoice number and invoice voucher has been picked only once and has been assigned to the first three entries of that journal. But for last two entries , it is not coming from that class … I even know that it has been picked from Inventory parameters → Number sequence → cost voucher … But in code level , I cant able to find … Requesting for your help
In this method \Classes\PurchInvoiceJournalCreate\getCostLedgerVoucher there is a condition check whether to use a single voucher. You should be able to debug and find out the same.
