Number Seq
In Ax
There is any possibility to create number seq without prefix’s
like serial numbers
example :
1
2
3
4
What happens when you leave the format field empty? If this is not possible then what you could have is 000001, 000002,… by setting the format to #######
Leave the format column empty, in number sequence form like fabricio said…It works
HI Ven Benz,
As said by Fabirico,in Basic – setup — NumberSequences — Number Sequence Form – select the numbersequencecode and make Format column to as empty.
Naresh Kolli
