I want to check for a field type date at the form entry level that if the user leave this field blank then it should raise an error. Although i have made it mandatory = YES but still when i click the button it did not check it. it will only work if i also modify any other field on the same block then click this button.
i am writing this condition to check the null
if table.datefield == ''
it is not working
plz help.
