I want to check for a field type string at the form entry level that if the user leave this field blank then it should raise an error.
i am writing this condition to check the null
if table.field1 == ’ '
it is not working
plz help.
it is not working
plz help.
should try :
if table.field1 == ""
or
if(table.field1)
regards
Thomas
hi,
y can’t u make that field’s mandatory property to ‘yes’
It’s not working
just make the field is mandatory by using properties or code
else write this below code in the validatewrite() method of the datasource
public boolean validateWrite()
boolean ret;
ret = super();
if (Table.Field1 == “”)
ret = checkfailed (“Enter the value”);
return ret;
First u hav 2 tel whether its alwys mandatory or to make mandatory based on the selected value in the other field
