Not the same UOM
Hi!
Good Day!
The Purchasing, Sales, Inventory Department are using BAG, PAIL, DRUM as unit of measurement for their transaction. While the BILL of MATERIALS is using KG as unit of measurement of the same item. My problem is that there is no unit of conversion between this two UOM. When i used BAG, PAIL, DRUM in Purchasing, Sales, Inventory Department transaction, error will appear when i used KG in BOM. Error states that there is no available conversion from BAG to KG. How can i solve this problem? is there is any solution for this?
Thank You very much
dear,
there is a conversion for this, you must enter in>> invenoty unit> go to main table> choose your unit of measure>> setup make conversion>> last tab in setup is example>> test it
I would recomment you do this from the item and setup button UOM conversion, the conversion in this instance is item specific and not global.
Hi!
Thanks for your response. is this solution is for AX 2012?
KG is Mass
Bag is Quantity
Hi Hardik Patel1
Thanks for your response. is this solution is for AX2012?
Kg is Mass
Bag is Quantity There is no available Conversion for this
Hi AdamRoue,
I follow you instruction. in item>>setup unit conversion>>Intra-class Conversion>> New
I select the Item Number, Factor is 1 Numerator is 1 Denominator is 20 from unit is Bag to unit is Kg
Error encountered: The from and the to units must belong to the same unit class.
Still i can’t do the conversion. Any mistake in what i did?
Thanks…
Hi AdamRoue,
Thank you very much… I found the solution in my problem with your help. Thanks.
Thanks also Hardik Patel.
