Not enough rights to use table 'Common' (UNKNOWN).
Dear AX friends,
When i open the “workflow status” i got this error message “Not enough rights to use table ‘Common’ (UNKNOWN).”
for every module in AX 2009. But my actual table name is WI_Workflowfilter, this is a customized table.
Give me your suggestions.
Subbu
Is the workflow status form is customized?For one of the data sources in the form you might not have access, identify it and change the AllowCheck property to NO
Thanks Kranthi its working properly…!
