Hi
At a german customer I cannot use the § sign in Navision. The problem is only in Navision. Even if I go directly in the SQL database there is no problem. I can copy/paste the sign into Navision.
Setup :
Version DE 4.0 SP3 (Obejcts 3.70)
Database : MS SQL
Collation Description : Western-European dictionary sort order, code page 1252, case-sensitive, accent-sensitive (51)
Has anyone had a similar problem ?
Regards
Jens
