I’m opening the form Dimension Values and select the field Code from another Form Control, in Nav 5.0 SP1.
I want that at the time of selection Code from the form (Dimension Values ) should be non-editable .
How Can I do ??
Thanks with regards.
DaveT
2
Hi Subrata,
You will need to give a more detailed example of what you want to do. Is it as easy as setting the code control property EDITABLE to FALSE?
i.e.
CurrForm.Code.EDITABLE(FALSE);
Dear DeveT,
Thanks for your reply…[:)]
Dimension Values is a base form in Navision.
And Its form property is editable (true) in base Navision.
I have stored some data from here.
And I can store/enter more data from here( Financial Management ----> Dimensions ---->Dimension -----> Dimension Values) also.
I have done some customization in my customized form XYZ.
Suppose Form XYZ has some control, which lookups the Form Dimension Values and select the data from it.
I want that when form Dimension Values is opend via my customization it should be non editable.
