After creating a PO I’m trying to do a receipt. I go to Warehouse - Receipts, “Function” and “Get source doucment”. Pick the PO and hit OK. Error message:
“There are no Warehouse Receipt Lines created”.
How are these lines created?
Seems you have already created warehouse receipt lines for this PO, using following steps:
You can check this by selecting that particular PO >>Order>> Whse. Receipt Lines.
Functions - Create Warehouse Receipts gives teh following error message:
The PO consists of one line.
That is what I said, you will get this error if you have already created Whse. Receipt Line.
On PO>> Order>> Whse. Receipt Lines then Lines>> Show Whse. Document. Check and you will find out your Receipt form, then press F11, and post it.
Hi again Dhan!
I do PO > Ordre > Whse. Receipt Lines
I get no lines. And the button “Line” is greyed out…
Check the warehouse setup for that location…and make sure that u have selected that location for that warehouse employee…
Thanks! I have been using NAV for almost a year and have had this problem every now and then…good to know what is causing it and how to fix it!
